713 visninger
traxxas tq {{forumTopicSubject}}
hej ville lige høre om der nogle der ved hvordan man "binder" traxxas tq 2,4 ghz modtager og sender
aug 2009
Følger: 15 Følgere: 17 RC-enheder: 19 Emner: 24 Svar: 330
TQ 2.4 Transmitter Binding Instructions
For proper operation, the transmitter and receiver must be electronically
‘bound.’ This has been done for you at the factory. Should you ever need
to re-bind the system, follow these instructions. Note: the receiver must be
connected to a 4.8-7.2v power source for binding.
1. Press and hold the transmitter’s SET button as you switch transmitter on.
The SET LED will flash.
2. Press and hold the receiver’s LINK button as you switch receiver on.
The LINK LED will flash.
3. When both LEDs stop flashing (this will take just a moment or two), the
system is bound and ready for use. Confirm that the steering and throttle
operate properly before driving your model.
maj 2011
Følger: 4 Følgere: 3 RC-enheder: 3 Emner: 20 Svar: 49
Den nye: http://www.trisdan.dk/receiver_2_4g_4_channel-p-2552.html
Gør det noget at de er forskellige?
traxxas tq
