Nyt Fwd Chassis fra MTS {{forumTopicSubject}}
Så lige at MTS har lavet et nyt FF chassis med rem som Huge/VBC
MTS FF Pro Car kit
1:10 MTS FF Pro Car kit Specifications:
- Belt direct drive system
- Front spring steel CVD shaft.
- Front gear differential with spring steel outdrive and hard coated metal gear.
- Spring steel turnbuckle and come with HD ball cups.
- Come with aluminum Floating Servo mount, gear diff mount, motor mount, suspension mount and locking wheel hex.
- The 2.5mm main chassis, 2mm upper deck, 2mm motor fan mount, 3mm front and rear shock tower are made by USA carbon fibre.
- High quality “shorty” aluminum hard coated big bore shock.
- Adjustable composite toe-in inserts in rear side.
- With aluminum stands to adjust the chassis stiffness to utilize different traction at different track conditions.
- Support 7.4V Shorty pack or standard size pack and square pack battery mounting with a little modification.
- Not include all electronic equipments.
Manual Download(Eng Ver):
http://www.race-opt.com/manual/MTS-FF-01-manual-09182014.pdf
http://www.race-opt.com/manual/MTS-FF-01-BreakDown-09182014.pdf
sep 2010
Følger: 12 Følgere: 14 RC-enheder: 20 Emner: 53 Svar: 365
sep 2010
sep 2010
sep 2010
sep 2010
dec 2009
sep 2010
dec 2009
Gå til gruppens forside
