1.158 visninger | Oprettet:  FølgFølg ikke 2 Svar
motor til slash ;) 4x4 motor til slash ;) 4x4
har bestil en ny motor til min slash og ville høre nogen af experterne om det er en godt valg smiley
Racerstar 3670 Sensorless Waterproof Brushless Motor 120A ESC For 1/8 Car
Description:
Brand: Racerstar
Item: 3670 motor & 120A ESC
Waterproof Level: Splash-proof
Motor Features:
- 4 pole 12 slot hi-torque motor design
- CNC hined 6061 T6 billet aluminum heatsink can
- High purity copper windings maximizes efficiency
- High RPM ABEC 5 oversized bearings
- Universal fit, fits all 1/8 brushless cars
- Precision balanced rotor, smoothness for best reliability and maxium RPM
- Stator- super thin 0.2mm laminations
- Removalbe/replaceable rotor
- Precision engineered for maxium energy coversion
Motor Specification:
Brand: Racerstar
Max Power: 1600W
Max Voltage: 24V
Max Amps: 66A
Rotor Poles: 4
Max RPM: 60K
Length: 70mm
Diameters: 36mm
Weight: About 275g
Shaft: Φ5mm
Length of Extend Shaft: 17mm
ESC Features:
- Specially desighed for RC car with excellent start-up, acceleration and linearity feartures
- Compatible with sensorless brushless motor
- The strong resistant current capability, excellent heat dissipation
- Multiple protection features: low voltage cut-off protection for lithium or nickel battery / over-heat protection / throtttle signal loss protection / motor blocked protection
- Easily programmed and compatible with pocket-sized program card
ESC Specifications:
Model120ACont./Burst Current:120A/600ASuitable Car1/8 Suitable Brushless Motor≥3.5TResistance0.00035ohmBattery2-6 cells Lipo
4-18 cells NiMHBEC Output6.1V/3A
(switch mode)Dimension41*51*36mmWaterproof LevelSplash-proof
Note:
If you use the motor ESC combo for 1/8 RC car, it would be better that you use 4s Lipo.
If you want to use 6s Lipo, please use with Racerstar 4068 motor or 4076 motor.
og ja opgradere lige min drivline inden den kommer i da det er tiltrængt smiley
og overvejer at bestille 4076 motoren hjem også så jeg evt. kan køre med 6s smiley
er det go eller no go med den motor ;)???
  • Fjerne murbrokker og træ 500 kr.
  • Samle to Ikea Metod skabe og hænge op over køleskabet 1.000 kr.
  • Kloak i badeværelse er tilstoppet der skal bruges en maskine for at kunne åbne det på da det er s afløb uden vandlås 625 kr.
  • Assemble Ikea cupboard 600 kr.
  • Nedrivning af fliser på badeværelse 1.000 kr.
  • Fjerne byggeaffald 2.500 kr.
Kommentarer på:  motor til slash ;) 4x4
