801 visninger
3 Svar
traxxas slash 2wd hurtigere i bak traxxas slash 2wd hurtigere i bak
Hejsa,
Har den her traxxas slash med 12 t titan motor o og xl5 esc. (med nimh batteri)
Jeg har opdaget at den er mere kvik i bak end fremad.
Jeg har prøve og vende motor ved at vende retning på servo (via fjernbetjening, som ikke er den originale)
Jeg har læst mig til at man kan bytte på to kabler på brushless system, men det her er brushs, der kan jeg vel ikke bytte rundt på dem to? ?? ??
sep 2019
Følger: 1 Følgere: 1 RC-enheder: 1 Emner: 1 Svar: 28
https://traxxas.com/sites/default/files/58034-1-OM-EN-R02.pdf#page=18
XL-5 Setup Programming (Calibrating your ESC and transmitter)
Read through all of the programming steps before you begin. If you get lost
during programming or receive unexpected results, simply unplug the battery,
wait a few seconds, plug the battery pack in, and start over.
1. Disconnect one of the motor wires between the XL-5 and the motor. This is a
precaution to prevent runaway when the speed control is turned on before
it is programmed.
2. Connect a fully charged battery pack to the XL-5.
3. Turn on the transmitter (with the throttle at neutral).
4. Press and hold the EZ-Set button (A). The LED will first turn
green and then red. Release the button.
5. When the LED blinks RED ONCE, pull the
throttle trigger to the full throttle position
and hold it there (B).
6. When the LED blinks RED TWICE, push the
throttle trigger to the full reverse and hold
it there (C).
7. When the LED blinks GREEN ONCE,
programming is complete. The LED will then
shine green or red (depending on LowVoltage Detection setting), indicating the
XL-5 is on and at neutral (D).
- jeg synes nu nok at man i første skridt kan nøjes med at vende bilen på hovedet, men det er nok en temperamentssag
mar 2020
Følger: 157 Følgere: 107 RC-enheder: 43 Annoncer: 1 Emner: 52 Svar: 477
maj 2011
