  • help installing 3 lamps in the apartment 600 kr.
  • Opsætning af lampe, tv og knage 1.000 kr.
  • Opsætning tv 900 kr.
Kommentarer på:  Specs på traxxas EVX Marine esc
  • #1   25. jul 2013 Hey
    Der er lidt her
    This speed control has low usage works great. This is the EVX Marine Electronic Speed Control By Novak for the Traxxas Villain EX boat.
    This can also be used on any dual motor boat kit. I'm sure it can be used for emaxx or other applications too. No manual or heat sink. Shipping is $6.00 or Free if the buy it now option is used.
    FEATURES:
    Orange Case with gray water cooled head.
    Two battery leads
    Two motor leads
    One-Touch setup.
    Reverse.
    Small black on/off switch.
    RPC (Radio Priority Circuitry) to maintain steering control even after battery has discharged.
    PDC (Polar Drive Circuitry) for cooler operation.
    Reverse disable circuitry for forward only operation.
    Has three user-selectable throttle profiles:
    Profile#1: Forward with brakes and reverse: Novak's smart braking circuitrybrings the model to a slow speed before engaging reverse.
    Forward and reverse are proportional.
    Profile #2: Forward only with Brakes: Novak's reverse disable circuitry locks out reverse for forward only or racing use. Brakes are enabled.
    Profile #3: Forward with 25% reverse and brakes: for applications w reduced speed in the speed in the reverse direction is desirable.
    SPECS:
    Input Voltage: 12 cells (14.4V).
    Case Width: 1.75" (44mm).
    Case Depth: 2.17" (55mm).
    Case Height: .085" (2.1mm).
    Weight: 3.5 ounces (99g).
    Motor Limit: 19-27 Turns.
    On-Resistance: (F).006 ohms (R).006 ohms.
    Rated Current: (F)160 amps (R)160 amps.
    Braking Current: 320 amps.
    Continuous Current: 30 amps.
    Reverse Delay: Zero Seconds.
    BEC Voltage: 5 Volts.
    BEC Current: 1.5 amps.
    Power Wire: 14G/ 9".
    Input Harness: 26G/ 9".
    Switch Harness: 26G/ 6".
    Transistor Type: Hyperfet III.
    PWM Frequency: 1000 Hertz.
    Protection: Thermal Shutdown.
    Mvh Brian
