543 visninger
10 Svar
hjælp til binding spectrum dx3r baja5b hjælp til binding spectrum dx3r baja5b
Hey, en i aalborg området der kan hjælpe mig med at få forbundet min spectrum dx3r (dsm2) og få failsafe til at virke, på min hpi baja 5b?
jul 2006
//Dan
jul 2009
Følger: 4 Følgere: 4 RC-enheder: 1 Emner: 9 Svar: 47
jul 2009
jul 2004
http://www.hpibajafan.dk/smf/index.php?action=googlemap
dec 2003
Følger: 8 Følgere: 9 RC-enheder: 8 Emner: 12 Svar: 151
Se dog lige på side 24:
1. With the receiver off insert the bind plug into the Batt/Bind port in the receiver.
2. Power the receiver. The amber LED will flash continuously, indicating that the receiver is in bind mode.
3. Turn on the transmitter and make sure the transmitter is in the desired model number that you intend to use.
4. Press the rolling selector to access the List screen.
5. Rotate the roller to highlight the Bind screen and press the roller to access this screen.
6. Rotate the roller to highlight BIND
7. With the steering wheel, throttle stick and Aux channel (if applicable) in the desired preset failsafe positions, press the roller to initiate the bind process and to store the failsafe positions. BIND will flash for a few seconds; then the transmitter will beep, indicating the process is complete. The LED on the receiver should now be solid, indicating a successful bind has taken place.
8. Remove the bind plug and store it in a convenient place.
Bingo....
jul 2009
jul 2009
jul 2009
nov 2007
Følger: 10 Følgere: 9 RC-enheder: 3 Emner: 4 Svar: 18
Følger: 107 Følgere: 200 RC-enheder: 46 Annoncer: 16 Emner: 107 Svar: 3.284
