1.676 visninger
21 Svar
Benzin motor problem.. Benzin motor problem..
Jeg har et lille problem med min baja..
Jeg kan fint få gang i den.. men lige så snart jeg røre gassen går den ud.. selv hvis jeg bare skubber den frem af går den ud.. er næsten godt klar over det er indstilling.. men har prøvet at skrue lidt på skruerne uden hjælp..
Er en stor noob med benzin motoere.. så hvis der en der lige ville gi en hurtig guide til at indstille den.. ville det være perfekt :)!
feb 2011
Happy Hunting ;o)
feb 2011
http://www.youtube.com/watch?v=gk3eC0aQ75E
feb 2011
Congrats! Listen, I have a King Motor (another 5b clone), and when I need specs or settings, I just refer to the HPI 5B manual on line (I just googled HPI 5B manual). To answer one of your questions: The low speed needle (closest to engine) stock setting is said to be 1 1/4 turns out from fully closed. The high speed needle (closest to the air filter) is said to be 1 1/2 turns out from fully closed. That will get you in the ballpark, then you can tune it from there (probably need to richen-up a bit for the pipe). If your problem persists, try turning the idle up until the car bucks, like the clutch is about to engage, then back the idle screw off 1/4 to 1/2 turn. Also, make sure you're mixing your gas properly. If you don't have enough 2-stroke oil in your fuel, it won't smoke. Buy a Ratio-Rite cup at your local motorcycle shop if you have doubts about how much oil to put in the gas. Lastly, go to the online manual (it's in PDF format) and check to make sure your throttle linkage is set up properly. Mine wasn't, right out of the box, and made it near impossible to start and run poorly. Good luck, hope this is some help.
nyt problem..
Den tøver når jeg gir gas og går nogen gange ud.. løfter jeg bagenden køre hjulene rundt.. sådan lidt hurtigt.. og har jeg kørt en lille tur og holder en lille pause så går den også ud
okt 2010
er karburatoren renset ? tændrøret og luftfilter i ok stand ??
feb 2011
Er den nu ell. gl? Har du tjekket for utætheder alle steder?
Og (Selv om det kan lyde åndsvagt) er din benzin gl.??
okt 2010
okt 2010
hvad benzin køre du på aspen, eller det fatter bruger til motorsaven ? :O)
Har du outerwears på dit luftfilter ? har det været vådt ?
køre ikke med aspen.. den begyndte at køre dårligt efter 1 tank ca..
kan ikke løfte bagenden ved at rive i snoren..
okt 2010
okt 2010
de dårlige kina kopier er ikke meget bevendt, de er af for ringe kval fra ende til anden.
Rens din karburator(skil den fuldstændig ad og blæs forsigtig alle huller og dyser rene og tørre)
rens dit luftfilter og sørg for at det er fuldstændig tørt for du giver det olie.
skift dit tændrør.
grund indstil din carb. og fyld noget benzin på tanken( noget frisk iblandet 4% god 2t olie eller 2%aspen-den røde)
og prøv om den ikke starter.
okt 2010
" og prøv om den ikke køre rimeligt" :O)
jul 2006
Magnus, kom til Holstebro i morgen så kigger vi på det, det er vist det nemmeste.
//Dan
okt 2004
Følger: 3 Følgere: 26 RC-enheder: 3 Emner: 29 Svar: 142
